Curveu Noise
i have a curve that is deforming and the topology is changing. So i cant use rest attribute
if i use a noise function it is point dependent and so gradually the curveu noise changes on my curve.
How can i add a noise to the curveu attribute independent of the points?
I want it to be static, somehow based on the curveu attribute so that it sticks on my curve no matter the deformation.
I can do this manually with a ramp parameter of course but i want it to be procedural with a seed value.
Essentially i want to do exactly what the ramp parameter does - remapping the curveu attribute - but using a noise
Any tips?
