jjstanley Posted January 7, 2007 Share Posted January 7, 2007 I am trying to get some simple fur happening and something is not right with it. When I comb the normals everything appears to be fine and looks good, but when I copy on the hairs some are correct, some lay flat and some go the opposite way! I have done this before and never had a problem but this just has me stumped. Any ideas? Quote Link to comment Share on other sites More sharing options...
stevenong Posted January 7, 2007 Share Posted January 7, 2007 Do you have a SOP modifying the Normals before the copy? I will bypass them one by one to see which is the culprit. Good luck! Cheers! steven Quote Link to comment Share on other sites More sharing options...
Jason Posted January 8, 2007 Share Posted January 8, 2007 Are you using the Fur SOP? Or just the Copy SOP? It kinda looks like your input single fur is along the wrong axis.. just make sure its lying along the Z-axis. If you're not using the Fur SOP, try it It's pretty good. Cheers, Jason PS. If you're using a Line SOP, its default it Y axis and you must change it if you're going to Copy it onto a template input's normals. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted January 8, 2007 Share Posted January 8, 2007 If you're not using the Fur SOP, try it smile.gif It's pretty good. Fur SOP?? Where/When did this happen? Or is that just an internal DD sop? Quote Link to comment Share on other sites More sharing options...
MADjestic Posted January 8, 2007 Share Posted January 8, 2007 Fur SOP?? Where/When did this happen? Or is that just an internal DD sop? Search the SideFX forum Quote Link to comment Share on other sites More sharing options...
SpencerL Posted January 8, 2007 Share Posted January 8, 2007 Search the SideFX forum Ah, thanks MADjestic...ill have to check it out. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted January 8, 2007 Share Posted January 8, 2007 There's an otl for it on exchange that you'll need too Quote Link to comment Share on other sites More sharing options...
