berkhak Posted July 21, 2021 Share Posted July 21, 2021 I am curious if it is possible to clock how long it takes to cook a surface operator and interrupt if it goes above a certain limit, preferably within a python SOP? Backstory; there are cases when a polyexpand2D node takes excessively long time to cook. I've contacted SideFX for this unexpected behavior. Long story short, this is what they recommended: Quote “The algorithm works by triangulating the plane and processing triangle collapses during the wavefront propagation. There's a lot of number crunching and decision making happening. Another trick that can sometimes work is to randomly adjust the positions of the input very slightly to knock it out of whatever worst case scenario is playing out.” And it does, when you translate the input geometry of the ‘polyexpand2d’ SOP the results do vary. So now I am trying to figure out a way to clock a particular section of the network tree, and if it takes longer than X amount of time, I want to translate the input ever so slightly. Hopefully this will help it so it doesn't take +1 hour to cook (average is somewhere between 1-5 seconds). I have been looking into hou.perfMon but that didn't really lead me anywhere. Let me know if anyone has any suggestions. Pseudo Code: import time trans_node = hou.node("../translate1") cook_node = hou.node("../COOK_THIS") start = time.time() time_limit = 5.0 rot= 0.0 while current_time < time_limit: try: cook_node.cook() except Timeout: rot= random(0.0, 360.0) trans_node.parm("rx").set(rot) cook_node.cook() continue Thank you! Quote Link to comment Share on other sites More sharing options...
animatrix Posted July 22, 2021 Share Posted July 22, 2021 Hi, Since PolyExpand2d is compileable, you can implement it as a Python wrapper using node verbs with your time out/retry logic: https://www.sidefx.com/docs/houdini/model/verbs.html Quote Link to comment Share on other sites More sharing options...
berkhak Posted July 22, 2021 Author Share Posted July 22, 2021 Hi, Great idea than one can wrap the node verb function around a decorator to limit the cook time. Found this tread that help me implement the decorator if anyone else is interested: https://stackoverflow.com/questions/492519/timeout-on-a-function-call Test Code for Houdini: import sys import threading from time import sleep try: import thread except ImportError: import _thread as thread def quit_function(fn_name): print(str(fn_name) + ' took too long') thread.interrupt_main() # raises KeyboardInterrupt def exit_after(s): def outer(fn): def inner(*args, **kwargs): timer = threading.Timer(s, quit_function, args=[fn.__name__]) timer.start() try: result = fn(*args, **kwargs) finally: timer.cancel() return result return inner return outer @exit_after(2) def countdown(n): # some function that can be run within Python SOP print('countdown started') for i in range(n, -1, -1): print(str(i) + ', ') sleep(1) print('countdown finished') try: countdown(5) except: print('do something else') Tesekkurler Yunus! 1 Quote Link to comment Share on other sites More sharing options...
