Alexey Vanzhula Posted August 26, 2021 Share Posted August 26, 2021 Soft Boolean technology, which was previously part of Modeler for Houdini addon, is now available as a separate product. Soft Boolean tools allow you to stitch polygonal meshes with boolean operations and adding accurate fillets to the resulting geometry. Houdini node can be used with the classical procedural way as well as with the help of special shelf tools. Also, the node can be used in other programs using Houdini Engine. The package contains a plugin for Houdini and some scripts for Maya. Release video: https://vimeo.com/592734907 Product link: https://alexeyvanzhula.gumroad.com/l/iWQyT Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted August 26, 2021 Author Share Posted August 26, 2021 Soft Boolean technology, which was previously part of Modeler for Houdini addon, is now available as a separate product. Soft Boolean tools allow you to stitch polygonal meshes with boolean operations and adding accurate fillets to the resulting geometry. Houdini node can be used with the classical procedural way as well as with the help of special shelf tools. Also, the node can be used in other programs via Houdini Engine. The package contains a plugin for Houdini and some scripts for Maya. Release video: https://vimeo.com/592734907 Product link: https://alexeyvanzhula.gumroad.com/l/iWQyT 1 Quote Link to comment Share on other sites More sharing options...
stephenvfx Posted September 14, 2021 Share Posted September 14, 2021 This is great! I just bought it, but it kept crashing every time when I dial the sliders. I'm currently using Houdini 18.5.633 python 2 on Win10 Is this Soft Boolean tool built against a specific Houdini version? Do you have a ticket system where I can file a bug report? Quote Link to comment Share on other sites More sharing options...
