archz2 Posted August 26, 2021 Share Posted August 26, 2021 I am trying to remove portions from a geometry which are not connected to it. I am using vdbsegment by connectivity. But it is giving me an error. It says 'no vdb grids to process' . What should I do to overcome this issue? vdb segmentation problem.hip Quote Link to comment Share on other sites More sharing options...
ryew Posted August 26, 2021 Share Posted August 26, 2021 You appear to be converting your VDB to polygons before running the VDB Segment By Connectivity - you'll need to leave it as a VDB for that node to do its work before converting to polygons Quote Link to comment Share on other sites More sharing options...
archz2 Posted August 27, 2021 Author Share Posted August 27, 2021 10 hours ago, ryew said: You appear to be converting your VDB to polygons before running the VDB Segment By Connectivity - you'll need to leave it as a VDB for that node to do its work before converting to polygons I converted chose VDB in the 'Convert to' drop down menu and the volume disappears totally. If I connect the volume vop output to vdb segment by connectivity, then it's also blank. vdb segmentation problem.hip Quote Link to comment Share on other sites More sharing options...
archz2 Posted September 5, 2021 Author Share Posted September 5, 2021 Bump.... Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted September 5, 2021 Share Posted September 5, 2021 Hi @archz2, try to create an SDF and avoid causing it any harm inside the volume VOP. vdb segmentation problem_2.hiplc Quote Link to comment Share on other sites More sharing options...
