Scale Smooth Strength
Jsmidlow
Hello. I have a basic sequence of grids intersected with object. I use Smooth node in order to smooth it))) and I like how it functions at the bottom but its too smooth at the top. I want slowly affect the model with smooth node so that it has fool affect at the bottom and low affect at the top. Its not a problem to create attribute that fads away closer to top... The problem is how to use the attribute. When I insert "@scaler" in "strength" param of smooth node it gives me "no local variable found".
Help
Thanks
