onesk8man Posted January 27, 2007 Share Posted January 27, 2007 Hi there, I'm having some problems with (i guess) the opengl on Houdini. I have an Intel 915 in a vaio laptop. I know, it's not a workstation. But I used to work on Maya with it, and I dont have any problems. I've to run houdini without hardware acceleration, becouse if I opening the help, the houdini console is outputting this message, before the crash: ""NT_GeneratorThread::queueEvent event queue full. Event dropped." I'm running Houdini on Windows, I don't know if there is any patch, or may works better on Linux or just Houdini doesnt support my card. I don't hope so. thank u in advance. Quote Link to comment Share on other sites More sharing options...
stevenong Posted January 27, 2007 Share Posted January 27, 2007 Hi, You can set the following environment variable which might prevent the crash: Name: HOUDINI_UI_QUEUE_SIZE Value: 99999 Cheers! steven Quote Link to comment Share on other sites More sharing options...
onesk8man Posted January 28, 2007 Author Share Posted January 28, 2007 (edited) Hi, thanks for the reply I found some fixer variables, and I fixed it forcing houdini to work with software, so probably is a opengl issue. Now doesn't crash, but is pretty slow. If someone knows a different way to fix it, please let me know. Here are the variables that I found, may they could be useful to someone. HOUDINI_OGL_SOFTWARE 1 (force software) HOUDINI_OGL_HARDWARE 1 (force hardware) HOUDINI_OGL_DBL_BUFFER_FIX 1 (nvidia patch) HOUDINI_UI_QUEUE_SIZE 99999 (queue size) bye! Edited January 28, 2007 by onesk8man Quote Link to comment Share on other sites More sharing options...
Mclawest Posted April 1, 2010 Share Posted April 1, 2010 (edited) so, is it works on Intel's cards? I tried, but it's not. Houdini just freeze again and again. Edited April 1, 2010 by Mclawest Quote Link to comment Share on other sites More sharing options...
kubabuk Posted April 1, 2010 Share Posted April 1, 2010 I found Houdini running pretty decent on Macbook GM965 (4th generation) starting from 10.6 OS. Although under 10.5 I used to have UI lag problems. Quote Link to comment Share on other sites More sharing options...
rachel12 Posted January 8, 2011 Share Posted January 8, 2011 I am also using Intel 915 in a vaio laptop and I had the same problem as you are facing. Some problem is solved by getting other views but here is still problem. If you will solve it then please tell me it will be helpful for me too. Thanks Quote Link to comment Share on other sites More sharing options...
