olivetty Posted October 15, 2021 Share Posted October 15, 2021 Hello all! I have this problem where my sweep is being flipped on random frames. It seems the points on my animated curve are jumping around in the spreadsheet (but not visibly). The curve is generated from a A-BSeam group from a boolean of a cylinder and a big noised-up box that goes through it. This is then resampled to get a constant pointcount. I'm resampling on every frame so this is the problem I think. The curve then travels upwards. I generate an up-vector with a simple wrangle @up = set(0,1,0); and then feed it into a sweep. The sweep looks fine and works well but on certain frames the whole thing flips and the sweep flickers. I've made a video to show the problem that you can see here: https://drive.google.com/file/d/13Ch6K2lNKK5diDRQggiNkFwXTKsC3GCP/view?usp=sharing Here is the HIP-file: https://drive.google.com/file/d/1M1WPRLivDL4PzK9v_1I99UOruoVweCVG/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted October 15, 2021 Share Posted October 15, 2021 (edited) SBUX_dl.hipncFetching info... EDIT: I meant to say "cross product" instead of "dot product" in the sticky note. Edited October 15, 2021 by dleonhardt 1 Quote Link to comment Share on other sites More sharing options...
olivetty Posted October 16, 2021 Author Share Posted October 16, 2021 On 10/15/2021 at 4:29 PM, dleonhardt said: SBUX_dl.hipncFetching info... EDIT: I meant to say "cross product" instead of "dot product" in the sticky note. Expand Awesome! Thanks so much for looking into it. Will disect and learn - thanks magician! Quote Link to comment Share on other sites More sharing options...
