caskal Posted October 18, 2021 Share Posted October 18, 2021 Hey magicians, anybody experienced this error with TOPs? "Work item ... as an expected output file, but it wasn't found when the item cooked". It works fine on my machine, but when I pack the scene (via archiveproject node) and run on my client farm, it shows this error. I did some troubleshooting and when the redshift proxy is off, it renders properly, any thoughts? Thanks! Quote Link to comment Share on other sites More sharing options...
caskal Posted October 18, 2021 Author Share Posted October 18, 2021 After some more debugging I think is an issue between TOPs and redshift proxy load. When I send the render via "save to disk" works fine, but when I send via TOPs > ROP FETCH > WAIT FOR ALL it gives the error. When I have other geometry without the RS PROXY it sends fine from TOPs Any thoughts? Thanks! Quote Link to comment Share on other sites More sharing options...
