yavahue Posted November 1, 2021 Share Posted November 1, 2021 I have a 1 object that consists of a ~1000 closed curves/splines (same ammount of primitives), i want to generate particles on each curve and move those particles along them, but each particle stays on that same curve it has been generated onto. i started with popnet with a force and a pop wrangle @P = minpos(1,@P); but of course the particles are jumping on the next spline when it comes near it, which i want to avoid. Also tried adding the popnet inside a for each prim loop, but not sure how to use metadata from that loop inside a popnet (particles disappear after the 1st frame) Can any1 please guide me on what logic i should be using? Quote Link to comment Share on other sites More sharing options...
Atom Posted November 1, 2021 Share Posted November 1, 2021 You may want to try using a carve node followed by a blast/delete to keep only point #0. This will allow you to move a point along each line, without dealing with popforces. ap_rnd_speed_point_along_line.hiplc Quote Link to comment Share on other sites More sharing options...
yavahue Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/1/2021 at 9:49 PM, Atom said: You may want to try using a carve node followed by a blast/delete to keep only point #0. This will allow you to move a point along each line, without dealing with popforces. ap_rnd_speed_point_along_line.hiplcFetching info... Expand Atom, thanks for reply. I tried your setup - it works good. Although i want a lot of points moving by each spline, not just one, with random speeds and directions. Quote Link to comment Share on other sites More sharing options...
Rence Posted November 3, 2021 Share Posted November 3, 2021 Grab MOPS and follow this - https://entagma.com/houdini-in-five-minutes-18-sops-redshift-mops-isocontours-setting-up-the-particles/ Quote Link to comment Share on other sites More sharing options...
yavahue Posted November 3, 2021 Author Share Posted November 3, 2021 On 11/3/2021 at 6:49 AM, Rence said: Grab MOPS and follow this - https://entagma.com/houdini-in-five-minutes-18-sops-redshift-mops-isocontours-setting-up-the-particles/ Expand YES!) i just upgraded to MOPs 1.5 - and you came up with this entagma tut! Thanks a lot! its just what i need! Quote Link to comment Share on other sites More sharing options...
