How can I select a specific group of faces for Poly Extrude
carl45456
One solution is to place a primitive wrangle before your polyextrude and use it to create a group based on primnum. Like this:
if(@primnum>100) i@group_extruders = 1;
Then direct the polyextrude to the "extruders" group.
I'm not sure why your solution doesn't work though.
You can add the prims to a group using a Primitive Wrangle like:
if(@primnum>100)
  @group_extrude = 1;
then in the PolyExtrude's Group field pick "extrude".
You can extend the functionality by replacing "100" with:
chi("threshold")
and then clicking the sliders icon on the right side of the textbox in the wrangle to create a parameter.
