Curve network - group branches
Is there an easy way to identify the dead-end branches of a curve network? so far i have a point wrangle that removes points if their neighbors are less than 2, but that is heavily depended on the iterations and it takes a lot of iterations to clean up a network from branches and keep only the closed loops.
Any ideas?
ok i found a solution in case anyone is interested.
instead of checking each point i look at the primitives.
in a primitive wrangle i look if any of the end points have less than two neighbors. i put that in a for loop with some iterations in case there are branches on branches. like ten iterations. before i had to go up to 100 and more to get rid of all the points,
int pts[] = primpoints(0,@primnum);
int f = pts[0];
int l = pts[-1];
int fn = neighbourcount(0,f);
int ln = neighbourcount(0,l);
if(fn<2 || ln<2) removeprim(0,@primnum,1);
