brandonY Posted February 3, 2007 Share Posted February 3, 2007 i been experimenting, and i was curious if it was possible to get values from cops to to drive shader values? Then apply the shader to any Sops i wanted? forgive some of my weird questions.. im probably over thinking things. Quote Link to comment Share on other sites More sharing options...
edward Posted February 3, 2007 Share Posted February 3, 2007 You should assign attributes to the SOP geometry based on COP information first. Then the attributes can drive your SHOP. Quote Link to comment Share on other sites More sharing options...
brandonY Posted February 3, 2007 Author Share Posted February 3, 2007 You should assign attributes to the SOP geometry based on COP information first. Then the attributes can drive your SHOP. thanks that worked out. Quote Link to comment Share on other sites More sharing options...
Jason Posted February 3, 2007 Share Posted February 3, 2007 thanks that worked out. You may also not know that you can import images directly from COPs into texture maps for shaders using a special syntax in your texture map fields. op:/img/img1/file1 ... will import the image generated by that COP into Mantra and render with it. Caveat: Be aware that these images are not filtered (they're in pic format internally, not rat); so a high-frequency textures may buzz at a distance. Quote Link to comment Share on other sites More sharing options...
brandonY Posted February 3, 2007 Author Share Posted February 3, 2007 You may also not know that you can import images directly from COPs into texture maps for shaders using a special syntax in your texture map fields. op:/img/img1/file1 ... while import the image generated by that COP into Mantra and render with it. Caveat: Be aware that these images are not filtered (they're in pic format internally, not rat); so a high-frequency textures may buzz at a distance. that is exactly what i was trying to do at first, thanks for the nugget of knowledge! Quote Link to comment Share on other sites More sharing options...
brandonY Posted February 4, 2007 Author Share Posted February 4, 2007 the houdini console comes up and says can't not find the texture when i try to render Quote Link to comment Share on other sites More sharing options...
