Rotating vellum boxes
davidyannick
This is because by default the vellum solver only takes the first frame of your input as the geometry to simulate. Luckily, you can add a vellum constraint called "Pin to Target" which allows you to match the vellum constraints to your animated input.
I have attached the updated hip file and added some notes to explain how this constraint works ^_^
vellum_box.hiplc
4 minutes ago, Ziyad said:
vellum_box.hiplc
Thank you so much, it works great !!!!
Cheers
