brucelay Posted February 3, 2007 Share Posted February 3, 2007 I am now using Houdini to buid my first human model. Then I will try to use z-brush to enhance it. Please feel free to give suggestions to me. Is my UV pelt working alright? I do not have much experience on it. Please give me some advice! I want to know if i am on the right direction. Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted February 3, 2007 Share Posted February 3, 2007 Nice job! UVpelt looks good to me. Check for overlapping polys and avoid ngons. Both will cause trouble in ZBrush. Read here for more informations. Quote Link to comment Share on other sites More sharing options...
Alexander Weide Posted February 4, 2007 Share Posted February 4, 2007 Yeah, you are on the right way. I have to say, dont stop to work in houdini. Iam a Maya Artist for years, and i'm learning houdini, since a couple of month. And its amazing, how fast and professional houdini can be. i dont miss maya. i'm using maya sometimes only for rendering. One little tip, order the book "The Magic of Houdini" you learn a lot from it. bye...... Quote Link to comment Share on other sites More sharing options...
brucelay Posted February 6, 2007 Author Share Posted February 6, 2007 But, the problem that I have is the eye and the mouth are circle in shapes. How can I solve this problem in Houdini. the attached image show the Unwrap which was done in Modo. (I downloaded this image from the net) Is it possible to have Houdini UVpelt working like this one? Mainframe123 said: Yeah, you are on the right way. I have to say, dont stop to work in houdini. Iam a Maya Artist for years, and i'm learning houdini, since a couple of month. And its amazing, how fast and professional houdini can be. i dont miss maya. i'm using maya sometimes only for rendering.One little tip, order the book "The Magic of Houdini" you learn a lot from it. bye...... Quote Link to comment Share on other sites More sharing options...
Alexander Weide Posted February 8, 2007 Share Posted February 8, 2007 i have to say, if you got problems in houdini with unwraping, unwrap in unfold or in modo. i got a unwrap problem, too Quote Link to comment Share on other sites More sharing options...
3dbeing Posted February 28, 2007 Share Posted February 28, 2007 the main difference here is that this model appears to be a closed mesh, be sure your mesh is air tight before pelting, to double check lay down a divide sop and turn on remove shared edges, this will show you where the "leaks" and hopefull provide you with geo to seal them. Quote Link to comment Share on other sites More sharing options...
masstapro Posted March 1, 2007 Share Posted March 1, 2007 brucelay said: But, the problem that I have is the eye and the mouth are circle in shapes. How can I solve this problem in Houdini. the attached image show the Unwrap which was done in Modo. (I downloaded this image from the net) Is it possible to have Houdini UVpelt working like this one? The only thing I can see is that you used a subdivide and got more polys. So your getting higher defined meshes around the eyes and mouth. The Modo mesh has less detail. Don't you want it smooth in these areas anyway? I see no problem. Quote Link to comment Share on other sites More sharing options...
MatrixNAN Posted August 5, 2007 Share Posted August 5, 2007 Hey Everyone, Make sure you pelt before you lay down a subdivide node. You will get much better results. You don't want a ton of polygons in your pelt. The unwrap will continue up the subdivisions if you do it in this manner. The houdini pelt system is certainly one of the best if not the best. You can also paint the tension on the peltmap if you go through SideFX's tutorials in the help. This of course is the extra special feature in the pelt mapping that I have not seen in any other package. There should be no reason that I can think of for not being able to do the same pelt in Houdini as in Modo. Its a good idea to break the ears out by themselves in the pelt. I did a the same thing with the eye sockets and the inside of the mouth. I love pelt mapping. Cheers, Nate Nesler Quote Link to comment Share on other sites More sharing options...
