anicg Posted December 29, 2021 Share Posted December 29, 2021 For one frame only, when I press Render to Disk on the USD Render ROP (for both Redshift and Karma), there is no progress visible on the screen (the usual pop up dialogue box with Mantra). How do I know how far the render is and if it's actually working other than sneaking in the destination folder? For a frame range, the progress bar does show up. Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted January 4, 2022 Share Posted January 4, 2022 The render time for one frame cannot be predicted; hence the absence of a progress bar; just render a frame in the render view, and look at the ETA at the start, and compare it to that actual render time. The progress bar for a frame range is linear in frames count, no global render time. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 4, 2022 Share Posted January 4, 2022 You should use the render in background button on the ROP. The percentage for a single frame will show up in the render scheduler dialog (which it should prompt to open when creating a background task). The scheduler is also available from the render menu at the top. 1 Quote Link to comment Share on other sites More sharing options...
