vector convert to xyz degree to rotate object
katosa
hello
I would like to ask about if i can use vector to make object rotate.
here is the scene I am working on.
I get vector from point 0 and 1.
and want to use that to rotate tube along 0-1 line.
I am not strong at math. and I want to know  which function I should use to change vector to xyz degree.
thank you for reading.
pipe_generate_v02.hipncFetching info...
Edited by katosa
You can use the dihedral function:
vector p0 = point ( 1, "P", 0 );
vector p1 = point ( 1, "P", 1 );
@orient = dihedral ( { 0, 1, 0 }, normalize ( p1 - p0 ) );
Position wise it's up to you if you want the tube to sit on point 0 or point 1, be centered to the line, or just rotate.
  On 1/1/2022 at 1:34 PM, katosa said:
thanksfully I could rotate tube.
still wish to know if vector xyz can be converted to xyz rotation degrees so that I can use in parameters in transform node.
Expand
Yes, you can convert @orient with the quaterniontoeuler() function, which will give you the rotation values in radians. You can then convert them to degrees with the degrees() function.
