Fluid-RBD interaction issue!
Masoud
Hello
I would like to create a Fluid-RBD interaction. But as you can see in the image below, the fluid pushes the rigid body so strongly.
I need the rigid body to be a little bit heavy and to float on the fluid, based on its mass attribute.
(Decreasing the "Feedback Scale", didn't help).
Thanks for helping.
RBD-FLIP Interaction_01.hip
Edited by Masoud
Feedback scale only works with RBD Hero objects.
What you can do is throw away your current RBD setup and create a new box.
Click the RBD Hero object to add it to your FLIP simulation and set the feedback scale back to 1.0.
