Confusion about CHOPs
Alright so I'm just starting to learn about C HOPs and now I understand the basics of it. From what I've learned, all my CHOP networks end with either an export node or a rename node. However, when I right click on parameter > Motion FX...
…I get this node tree
I have two questions :
1) How does it "export" the data without an export or rename node? I checked the wave node and saw this as the channel name : 'run("chopls ../wave_transform1_clip1")' Not sure what this means or how it works as the export.
2) The math node is set to Combine CHOPs : Add. I know how adding channels are like, but what does it mean to add two CHOPs together?
