DHartleRyan Posted January 19, 2022 Share Posted January 19, 2022 Hello I am new to Python. I have been avoiding it for sometime. I have an object which is split into 100 tiles via connectivity and a class attribute which I would like to export into Unreal engine but as 100 separate static meshes. Therefore I would like to split the geometry into 100 different Geometry nodes in a subnetwork, appropriately named. How would I go about achieving this using Python? Thanks in advance Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted January 19, 2022 Share Posted January 19, 2022 Hi Daniel, maybe this thread could get you started: Quote Link to comment Share on other sites More sharing options...
DHartleRyan Posted January 20, 2022 Author Share Posted January 20, 2022 20 hours ago, konstantin magnus said: Hi Daniel, maybe this thread could get you started: Thanks Magnus, you're a wonderful fellow. This worked great, I seem to be doing the exact same project you did 3 years ago. To anyone reading. To add a Python expression to your Geometry File Path, you need to set the node to Python instead of H script (top right hand corner) then KEYFRAME THE PARAMETER (alt left-click Geometry File input) then you can add your Python expression. I am new to Python so created the file path in VEX then promoted it to a detail attribute and used. hou.pwd().node("../ReplaceWithNodeWithAttribute").geometry().attribValue("ReplaceWithDetailAttribute") Quote Link to comment Share on other sites More sharing options...
