Deform along curve
Hello everybody :)
I have a little problem, I'm trying to deform my fabric along a curve.
I tried the path deform, but it flattens my shape every time...
The only solution I've found so far is using the vellum brush, but it's long and I'd like a more "procedural" method...
Ideas ?
Pathdeform.hiplc
BTW: the most elegant way of course is using vellum. Give it a try...
and if you are not satisfied with the onPath solution use yout own Velocity field with 2 vectors: one for the path direction, one for pushing it inward to the path.
i.e. Tim van Helsdingen: Better curve force
As vellum is point based solver you are able to use all the fine POP nodes for artdirecting your path movement...
