Render transparent background in arnold
make sure that you save your image as .png or exr.
A .jpg for example is not able to store an alpha channel.
If you want to save out multiple render passes, you need to save out you image as exr. Exr is the most common Image type to save out multiple passes.
In your case the background should be transperant by default. just make sure you added the right filename extension when you save out your png or exr.
Edited by Varaya
