Jack16277 Posted February 14, 2022 Share Posted February 14, 2022 (edited) Hello! I'll try to explain it quickly, I have created a tree, with trunk and leafs, and created a packed USD. I am using solaris/karma to render lots of instanced copy of the tree, and it works, but...sometimes the trees lose their leafs for some reason. The odd thing is, if go inside the instancer node (inside lops) and mess around with the "method" parameters, sometimes the leafs comes back, sometimes they disappear again (selecting method that didn't worked before), like a russian roulette basically... It's very odd and it feels like it's a bug, or am I missing something? Edited February 14, 2022 by Jack16277 Quote Link to comment Share on other sites More sharing options...
DaJuice Posted February 15, 2022 Share Posted February 15, 2022 What version of Houdini are you on? Quote Link to comment Share on other sites More sharing options...
Jack16277 Posted February 15, 2022 Author Share Posted February 15, 2022 (edited) 9 hours ago, DaJuice said: What version of Houdini are you on? Houdini 19.0.498 (Apprendice) I have done some rendering also, and the leafs appears/disappears in every frame Edited February 15, 2022 by Jack16277 Quote Link to comment Share on other sites More sharing options...
ryew Posted February 17, 2022 Share Posted February 17, 2022 I would suggest posting this issue to the SideFX forums if you haven't done so already, although they do visit here sometimes, there is a far greater chance a SideFX engineer will see it over there to investigate or explain. Perhaps this is a known bug Quote Link to comment Share on other sites More sharing options...
