Q: avoid rendering from inner particles
Follyx
You could create a surface out of all the particles (vdbfromparticles followed by a convertvdb to polygons that you connect to the second input of a group node), and group those on the inside. Issue a delete on that group before you render. It might not look exactly the same, depending upon what materials you are using.
