bratro Posted March 4, 2022 Share Posted March 4, 2022 I'm trying to have a shape bend a bit more with every copy like in the example below. I though that for each would be a good choice for that but I can't manage to recreate it. This is what I made so far but it's not working exactly like I would like to :-) ForEach.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 4, 2022 Share Posted March 4, 2022 @bratro how to use att in foreach _ plus you have Houdini Kitchen for how to use L-system ..you have more Variation in L-system..maybe a little bit slow compering with Sop manipulation but Quote Link to comment Share on other sites More sharing options...
Mazl Posted March 4, 2022 Share Posted March 4, 2022 Hi Roman, unfortunately I can´t look into your file or post one right now. but this would be the way to go... right now you have only one iteration... put your copy2 node above the connectivity2 on your bend node -Add Spare Input drag your metadata "info" node into that spare parameter. in bend amount, you can then multiply the iteration by your stepsize, like detail(-1,"iteration",0) * 5; Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 4, 2022 Share Posted March 4, 2022 Hi, here is a simple example using bend in foreach. bend_foreach.hipnc Quote Link to comment Share on other sites More sharing options...
bratro Posted March 7, 2022 Author Share Posted March 7, 2022 On 3/4/2022 at 12:32 PM, Aizatulin said: Hi, here is a simple example using bend in foreach. bend_foreach.hipnc thanks for that setup, that is definitely what I was looking for. I just have to find a way to make it without remeshing to have nicer shaped discs :-) Quote Link to comment Share on other sites More sharing options...
bratro Posted March 7, 2022 Author Share Posted March 7, 2022 On 3/4/2022 at 12:30 PM, Mazl said: Hi Roman, unfortunately I can´t look into your file or post one right now. but this would be the way to go... right now you have only one iteration... put your copy2 node above the connectivity2 on your bend node -Add Spare Input drag your metadata "info" node into that spare parameter. in bend amount, you can then multiply the iteration by your stepsize, like detail(-1,"iteration",0) * 5; thanks for your input. I will try this one out! Quote Link to comment Share on other sites More sharing options...
