Clean CAD Data for Rendering
Ultron
I imported CAD Data via stp and Unreals Datasmith (great workflow). Now I have the Files in Houdini and they came in fine but much more geometry than I need. Besides Poly reduction I want to do 2 Things to reduce the Polycount:
1. There are a lot of Drillings in Steel plates which can´t be seen in Rendering - is there a way to procedural close them
2. There are Tubes with width. Is it possible to procedural delete the geometry inside a Tube
Would be nice if you could give me a hand on this to topics :)
Shure here are some Pictures
There are a lot of Tubes and Plates with holes like this.
I now addes a fbx File as well (under the Window). Houdini is mighty this must be solvable procedurally!
Sample.fbx
Edited by Ultron
added an FBX
Wow completly different approach than I would have thought - Really Effective and I learned a lot. Thanks you!
But what if the Tube isnt Straight but bended or even more complex Shaped- is there a way to delete Faces with normals facing to the inside of the Object?
I uploaded a sample file
Sampe_Tube.fbx
  • 2 months later...
