Python - get nodes contained in network box
Are you sure your netbox is named "Mynetworkbox"? The title of the netbox is not its name, rather it is a "comment", which you can retrieve with the comment() method.
If you use the networkBoxes() method, you can get the names of all the netboxes in the specified node. The names of netboxes are typically in the form [double_space]netbox#
Edited by Fenolis
