findind the way to fix these gaps in geometry
hello all, iam just dong a wall tool but i found that if my line is in curve shape i might get some gaps in-between the bricks. is there any way to fix these thing and i also found that some of the bricks are intersecting with each other. it will be a issue while doing RBD. is there any way to fix these things
  • 3 weeks later...
You can use the Chain SOP to place your brick models along curves with less overlap issues. Gaps are formed because your model is rigid and low-poly - you can give your brick models more geometry resolution and use Copy + Creep SOP to "bend" them along a NURBs surface, which can be created by extruding your curves upwards and Converting them to NURBs surfaces.
Quote
Sometimes keep some proper gaps for RBD is a good idea,overlaps among different RBD objects have to be fixed.
overlap_gap_fix_od.hip
