jacksper Posted April 16, 2022 Share Posted April 16, 2022 hello all, iam just dong a wall tool but i found that if my line is in curve shape i might get some gaps in-between the bricks. is there any way to fix these thing and i also found that some of the bricks are intersecting with each other. it will be a issue while doing RBD. is there any way to fix these things Quote Link to comment Share on other sites More sharing options...
Fenolis Posted May 6, 2022 Share Posted May 6, 2022 You can use the Chain SOP to place your brick models along curves with less overlap issues. Gaps are formed because your model is rigid and low-poly - you can give your brick models more geometry resolution and use Copy + Creep SOP to "bend" them along a NURBs surface, which can be created by extruding your curves upwards and Converting them to NURBs surfaces. Quote Link to comment Share on other sites More sharing options...
Benyee Posted May 6, 2022 Share Posted May 6, 2022 Quote On 2022/4/16 at 3:35 PM, jacksper said: hello all, iam just dong a wall tool but i found that if my line is in curve shape i might get some gaps in-between the bricks. is there any way to fix these thing and i also found that some of the bricks are intersecting with each other. it will be a issue while doing RBD. is there any way to fix these things Sometimes keep some proper gaps for RBD is a good idea,overlaps among different RBD objects have to be fixed. overlap_gap_fix_od.hip Quote Link to comment Share on other sites More sharing options...
