PwPwPower Posted May 27, 2022 Share Posted May 27, 2022 I have a vellum soft body simulation, and I want to use a point deformer to deform the render body based on the vellum simulation. It works on the first few frames, where the model is close to the rest pose, but as the animation moves forward, the deformation gets weirder. I also try cloth capture&deformer, buts it doesn't do anything. I check and the point number stays consistent during the animation (both on the render body, and the vellum sim as well), change parameter in the point deformer node also doesn't help. Quote Link to comment Share on other sites More sharing options...
PwPwPower Posted May 27, 2022 Author Share Posted May 27, 2022 HIP file: vellumPointDeformer.zip Quote Link to comment Share on other sites More sharing options...
ryew Posted May 28, 2022 Share Posted May 28, 2022 (edited) Switching the PointDeform Mode to only "Deform" instead of "Capture & Deform" appears to work better although not perfectly. I suspect you are getting double transformations by adding the deforming simulation cache on top of the animation of the character movement. I've only ever used PointDeform to deform static meshes and it has typically worked for that. Attached is a quick hack to subtract the difference in your characters motion from the rest position, it seems to line back up well. There was also a point on the character's arm that was included in your deformation set, so I removed that and set the points up through a Group SOP instead of the point list originally in there. vellumToBody_tweaked.hiplc Edited May 28, 2022 by ryew Quote Link to comment Share on other sites More sharing options...
Rence Posted May 30, 2022 Share Posted May 30, 2022 Hi PwPwPower, See attached hip file. That's how I would approach it. lj_vellumToBody.hiplc Quote Link to comment Share on other sites More sharing options...
