Vellum grain clustering pieces issue...
Masoud
Hi guys,
In a Vellum grain sim, I would like several chunks (clusters) to interact, but not stick to each other.
As you can see in the image below they stick after the collision. How can I fix it?
According to the documentation, there is an option in the Vellum Solver node called "Ignore Neighbors in Same Piece":
https://www.sidefx.com/docs/houdini/nodes/dop/vellumsolver.html
Quote
Ignore Neighbors in Same Piece: Ignore any neighbors that have the same non-negative value for the piece point attribute. This option can be enabled to create separate clusters of grains that only interact with other clusters, often in conjunction with a Shape Match constraint to give rigid behavior. The VDB To Spheres SOP can be a good method for filling objects with overlapping grains.
I tried to use this option, but it doesn't work.
Thanks for helping.
Vellum Grain_02.hip
