Can the direction vector be expressed in uv coordinates?
hello.
I created a water mesh based on splines.
So the water mesh has a tangent vector.
I want to generate uv as a tangent vector.
So I want to offset the uv.y values to create the effect of a flowing texture.
Is it possible?
Edited by saelly
What is you goal? It's a bit hard to understand (at least to me).
Uv is a vector attribute so of course you can just convert your directional vector to uv, but I assume that is not what you mean.
Maybe you can show simple example file?
Edited by saelly
