immeen Posted June 13, 2022 Share Posted June 13, 2022 Originally, I made a fountain, but if I just play, it comes out well, but if I go over to Niagara, it doesn't play. I set it up like the image above It doesn't play in "niagara" at all OrgPlay.mp4 Quote Link to comment Share on other sites More sharing options...
wacool Posted June 17, 2022 Share Posted June 17, 2022 Are other SideFX plugin functions working properly? i mean they might have some errors like in the picture, some nodes need to be reconected, also you need to sheck the SideFX_Utilities_BP for errors Quote Link to comment Share on other sites More sharing options...
Heinson Posted July 1, 2022 Share Posted July 1, 2022 Have you activated the legacy data in the Material Instance? You would need to export that data from Houdini, though Quote Link to comment Share on other sites More sharing options...
Soomin Posted October 14, 2024 Share Posted October 14, 2024 Make sure check the box of UV Full precision in Static Mesh first. In case if it's not working though, make sure close the whole material tabs if they're opened. It would automatically apply the setting in veiwport nicely. Quote Link to comment Share on other sites More sharing options...
pandapin223 Posted 10 hours ago Share Posted 10 hours ago On 10/14/2024 at 1:31 PM, Soomin said: Make sure check the box of UV Full precision in Static Mesh first. In case if it's not working though, make sure close the whole material tabs if they're opened. It would automatically apply the setting in veiwport nicely. Labs VAT > Advance > (Allow Exporting Real-Time Data JSON File (Legacy) ON and Support Real-Time Instancing on) Mkaing this Option ON Houdini Will Export data.json file open That and copy bound min max xyz values to ue material instance. this should work properly with niagara. Quote Link to comment Share on other sites More sharing options...
