revelationsr Posted July 27, 2022 Share Posted July 27, 2022 Hello. I have a ocean Spectrum. I would like to drive the amplitude of the waves based off an attribute I have placed on the scattered points. I have tried using the "point" vex in the "wave instance"/"amplitude" . But no matter how I try it I can only seem to effect the entire spectrum at the same time. No individual point data is being used. Am I going about this the correct way. Is there something else I should be doing? Cheers Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted July 27, 2022 Share Posted July 27, 2022 (edited) The Ocean Spectrum will expect special attributes if you want to go this way. To drive the Amplitude by hand you need to disable the Amplitude parameter on the Ocean Spectrum and create the @amplitude attribute on your scattered points. Or you can instead modify the @amplitude attribute created by the Ocean Spectrum before it goes to the Ocean Evaluate. Edited July 27, 2022 by dleonhardt Quote Link to comment Share on other sites More sharing options...
revelationsr Posted July 27, 2022 Author Share Posted July 27, 2022 Great thank you. I will try it in the morning Quote Link to comment Share on other sites More sharing options...
kio0o Posted May 30 Share Posted May 30 Hey, a little bit late, but I am trying to achieve the same thing. Did you manage to guide the amplitude with an animated attribute? Can you give me some tips? Quote Link to comment Share on other sites More sharing options...
sipi Posted May 31 Share Posted May 31 On 5/30/2025 at 10:26 AM, kio0o said: Hey, a little bit late, but I am trying to achieve the same thing. Did you manage to guide the amplitude with an animated attribute? Can you give me some tips? Hi, Here's a hipfile for this: drive_ocean_amplitude.hiplc 1 Quote Link to comment Share on other sites More sharing options...
kio0o Posted June 6 Share Posted June 6 Hey thank you very much. I tried controlling scale and amplitude of the waves with instances, the issue I will be facing is that I have to do that for a small scale tank, like a room full of floating tables. So I kind of need to control the individual waves. I think at the end I will try a mix of controlled amplitude based on a mask attribute, and combination of spectras with masks, plus some additional velocities based on the tables positions. Quote Link to comment Share on other sites More sharing options...
