archz2 Posted July 29, 2022 Share Posted July 29, 2022 (edited) I am following this youtube tutorial for VEX. https://www.youtube.com/watch?v=9xhmDWAyPRA At 14 min 48 seconds, he achieves a bounce effect. However, when I press the play button, the shape doesn't act that way. It only expands and contracts once. I have typed in the same code but the ramp isn't resetting the shape after regular time intervals. What is it that I am doing wrong? VEXISNTSCARY_PART4_channel func_query.hip Here's a short screenrecording that I made vex question.mp4 Edited July 29, 2022 by archz2 Quote Link to comment Share on other sites More sharing options...
animatrix Posted July 30, 2022 Share Posted July 30, 2022 Hi, I haven't seen this tuto, but you can explicitly keep the fraction part of the time like this: float blend = @Time % 1.0; Otherwise the values get larger than 1, and so the ramp caps them at 1, hence why the "bounce" stops. 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted July 30, 2022 Author Share Posted July 30, 2022 Thanks a lot . Editing the time worked really well. Can you also check out the tutorial please? I wonder why the same line of code worked for the tutor but not for me. Quote Link to comment Share on other sites More sharing options...
animatrix Posted July 31, 2022 Share Posted July 31, 2022 15 hours ago, archz2 said: Thanks a lot . Editing the time worked really well. Can you also check out the tutorial please? I wonder why the same line of code worked for the tutor but not for me. It seems like SESI changed the behaviour of ramps so now no more implicit cycling behaviour. The author needs to update his tuto. 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted July 31, 2022 Author Share Posted July 31, 2022 (edited) 1 hour ago, animatrix said: It seems like SESI changed the behaviour of ramps so now no more implicit cycling behaviour. The author needs to update his tuto. I see. Thanks again. Edited July 31, 2022 by archz2 Quote Link to comment Share on other sites More sharing options...
