Add texture to light... - Lighting & Rendering + Solaris! - od|forum Jump to content
I've noticed that there's a "texture map" parameter on Area Light Options, and it's described to be using UV's to project a texture map onto the light plane. However,  I can't find a way to modify the UV of the light, even when I dive inside the Light node and drop down some UV related nodes...
Is there any ways to do that?
Thank you!
I don't think UVs have anything to do with it. Try changing the size of the area light. That changes the projection size of the texture rendered by Karma.
Edited by Atom
