(Solved) Incorrect Orientation converting 3@transform to p@Orient using quaternion()
3@transform = set( {-0.146396,-0.0727609,0.0550026},{0.0605058,0.000363445,0.161525},{0.0682531,-0.156387,-0.0252152} ) ;
 -- Instance with @transform
p@orient =  quaternion(3@transform);
DELETE @transform attribute
 -- Instance with p@orient
Different Results of orientation!
If I instance the point with p@Orient  converted from 3@transform using quaternion() ,  the orientation is flipped .
It seems that  I get the same p@Orient value with   ident()  and  ident() * -1 .
Is it the problem?
How can I obtain the correct p@orient ?
Thank you for reading my question
Edited by sawyerwolf19
17 hours ago, uakin said:
I think there is an error in the definition of matrix.
USE THIS:
 3@transform = set( {0.848744,0.421838,-0.318882},{-0.350787,-0.00210714,-0.936453},{-0.395704,0.906669,0.1461872} ) ;
Thanks for replying!
Sorry I dont understand what is the error ?
The 3x3matrix is from a leaf instance point exported from SpeedTree.
2 hours ago, j00ey said:
I think the orientation is actually working correctly but if you do a cracktransform on that matrix you'll see that it has a negative scale
Attached is a test scene that hopefully explains
orient_problem.hiplc
Thank  you for replying!
Yes, there is a " negative scale transformation" in the 3x3 Matrix.
I guess I have to extract "scale" from  3x3 Matrix to check if there is a" negative scale transformation" inside for every 3x3 Matrix getting from other softwires.
At a guess I'd say it's likely that if it's coming from the same software it will happen the same but I don't know for sure. Could it be something to do with handedness of Speedtree vs Houdini perhaps?
You don't necessarily need to check each time, you could maybe make an asset, or even just a wrangle preset to check the scale and correct it if it's negative.
I guess all components of rotation matrix should be 1 unit long
