sawyerwolf19 Posted September 8, 2022 Share Posted September 8, 2022 (edited) 3@transform = set( {-0.146396,-0.0727609,0.0550026},{0.0605058,0.000363445,0.161525},{0.0682531,-0.156387,-0.0252152} ) ; -- Instance with @transform p@orient = quaternion(3@transform); DELETE @transform attribute -- Instance with p@orient Different Results of orientation! If I instance the point with p@Orient converted from 3@transform using quaternion() , the orientation is flipped . It seems that I get the same p@Orient value with ident() and ident() * -1 . Is it the problem? How can I obtain the correct p@orient ? Thank you for reading my question Edited September 9, 2022 by sawyerwolf19 Quote Link to comment Share on other sites More sharing options...
uakin Posted September 8, 2022 Share Posted September 8, 2022 I think there is an error in the definition of matrix. USE THIS: 3@transform = set( {0.848744,0.421838,-0.318882},{-0.350787,-0.00210714,-0.936453},{-0.395704,0.906669,0.1461872} ) ; Quote Link to comment Share on other sites More sharing options...
sawyerwolf19 Posted September 9, 2022 Author Share Posted September 9, 2022 17 hours ago, uakin said: I think there is an error in the definition of matrix. USE THIS: 3@transform = set( {0.848744,0.421838,-0.318882},{-0.350787,-0.00210714,-0.936453},{-0.395704,0.906669,0.1461872} ) ; Thanks for replying! Sorry I dont understand what is the error ? The 3x3matrix is from a leaf instance point exported from SpeedTree. Quote Link to comment Share on other sites More sharing options...
j00ey Posted September 9, 2022 Share Posted September 9, 2022 I think the orientation is actually working correctly but if you do a cracktransform on that matrix you'll see that it has a negative scale Attached is a test scene that hopefully explains orient_problem.hiplc 1 Quote Link to comment Share on other sites More sharing options...
sawyerwolf19 Posted September 9, 2022 Author Share Posted September 9, 2022 2 hours ago, j00ey said: I think the orientation is actually working correctly but if you do a cracktransform on that matrix you'll see that it has a negative scale Attached is a test scene that hopefully explains orient_problem.hiplc Thank you for replying! Yes, there is a " negative scale transformation" in the 3x3 Matrix. I guess I have to extract "scale" from 3x3 Matrix to check if there is a" negative scale transformation" inside for every 3x3 Matrix getting from other softwires. Quote Link to comment Share on other sites More sharing options...
j00ey Posted September 9, 2022 Share Posted September 9, 2022 At a guess I'd say it's likely that if it's coming from the same software it will happen the same but I don't know for sure. Could it be something to do with handedness of Speedtree vs Houdini perhaps? You don't necessarily need to check each time, you could maybe make an asset, or even just a wrangle preset to check the scale and correct it if it's negative. Quote Link to comment Share on other sites More sharing options...
uakin Posted September 15, 2022 Share Posted September 15, 2022 On 9/9/2022 at 7:47 AM, sawyerwolf19 said: Thanks for replying! Sorry I dont understand what is the error ? The 3x3matrix is from a leaf instance point exported from SpeedTree. I guess all components of rotation matrix should be 1 unit long Quote Link to comment Share on other sites More sharing options...
