Modify item in OPmenu
DonRomano
Hey guys,
I try to modify a few items in the OPmenu (the menu triggered when right-clicking on nodes). I want to modify the expressions that enable certain items, for example disabling the Type Properties... for specific nodes.
Following the documentation, I came up with the following xml file that is in a directory in the HOUDINIPATH
<?xml version="1.0" encoding="UTF-8"?>
<menuDocument>
    <menu>
        <modifyItem id="opmenu.properties">
            <context>
                <expression><![CDATA[
# some example python code to evaluate an expression
expression = node.type().name() == "custom_nodetype_name"
return expression
                ]]></expression>
            </context>
        </modifyItem>
    </menu>
</menuDocument>
And Houdini returns an error when firing the menu, telling it cannot find element "opmenu.properties". I tried with other items I've found in the "internal" OPmenu.xml file, and I keep having the same error.
Anyone has any hints on this ?
