Object merge and relative path
def merge_multiple_objects(objs):
    obj_container=objs[0].parent().createNode('geo','merged_objs')
    merge_sop=obj_container.createNode('object_merge')
    merge_sop.parm('numobj').set(len(objs))
    for i in range(len(objs)):
        relPath = merge_sop.relativePathTo(objs[i])
        merge_sop.parm('objpath'+str(i+1)).set(relPath)
    merge_sop.parm('xformtype').set(1)
    #orgnize node positions
    pos=objs[-1].position()
    obj_container.setPosition([pos[0]+2,pos[1]-2])
sels=hou.selectedNodes()
merge_multiple_objects(sels);
you can try the script as a python shelf tool by selecting objects first, hope it helps
gonna do this thanks for your hepl :)
