Ultraman Posted October 17, 2022 Share Posted October 17, 2022 (edited) Hey Guy - there is any way to load all light into IFD then just a few Light effects on the Image and the rest of them be in the AOV Pass ? im not sure my question is correct ;( i have 2 main lights just wanna effect on my Final image in Exr file and ther then be Auxiliary or like Attribut but actually is real Light . i Don't wanna make two Mantra Node , to do Dirty Way hope my explanation be clear what I'm saying Thanks in advance. Edited October 17, 2022 by Ultraman . Quote Link to comment Share on other sites More sharing options...
rodmac Posted October 17, 2022 Share Posted October 17, 2022 If the question is can you have an AOV containing lighting info that is not in the RGB then I think yes. However in your shader you would need to set what amounts to another shader tree to then feed your bind AOV (which probably will take twice as long to render) if you really want to keep it out of the beauty RGB. So either you dirty your renders or you dirty your shader. 1 Quote Link to comment Share on other sites More sharing options...
Ultraman Posted October 17, 2022 Author Share Posted October 17, 2022 On 10/17/2022 at 3:31 PM, rodmac said: If the question is can you have an AOV containing lighting info that is not in the RGB then I think yes. However in your shader you would need to set what amounts to another shader tree to then feed your bind AOV (which probably will take twice as long to render) if you really want to keep it out of the beauty RGB. So either you dirty your renders or you dirty your shader. Expand Thanks Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted November 10, 2022 Share Posted November 10, 2022 If you're rendering each light to aovs anyway, you can just subtract the light from the rgb after rendering 1 Quote Link to comment Share on other sites More sharing options...
