Connecting points by "id", issue!
Masoud
That's because all your IDs are unique. Add can only connect a series of points that share the same ID. Try altering your wrangle to this and observe the result.
if (@ptnum==0){i@id = 0;}
if (@ptnum==1){i@id = 0;}
if (@ptnum==2){i@id = 0;}
if (@ptnum==3){i@id = 1;}
if (@ptnum==4){i@id = 1;}
if (@ptnum==5){i@id = 1;}
if (@ptnum==6){i@id = 2;}
if (@ptnum==7){i@id = 2;}
if (@ptnum==8){i@id = 2;}
I often use Add following a trail sop out of particle system to create lines from a particle in motion. Trail count becomes line length in that type of setup.
Edited by Atom
Expand
i@id = @ptnum % 3;
