Camera auto framing
Hello,
I am currently trying to build a asset turntable tool, most things are fine, but now i am looking for a way to automatically move the camera for and back in z to make sure, that the framing of the object is good (not too far away and not too close to avoid any clipping).
The camera has no rotation. using the center of the bounding box of my asset as y position and the focal length is also fixed.
whats the best approach to calculate the distance in z ?
thank you for the help!
Edited by Crustedink
21 hours ago, tamagochy said:
I'm using this:
(max(bbox(-1,D_ZSIZE),max(bbox(-1,D_XSIZE),bbox(-1,D_YSIZE)))/2)/sin(2*atan((ch("../cam1/aperture")/2)/ch("../cam1/focal"))/2)
bounding box of the render object
thanks for the reply, sorry for the silly question, but can you explain it a bit further ? so where and how are you using it ?
-//edit
NVM, its workign now. thank you
  • 2 years later...
-//edit
Just came across this post. Could you please explain what you did ? I didn't understand what to do.
Cheers...
