anicg Posted January 4 Share Posted January 4 I've tried: if(find(s@name,"rock")==1) @group_rock=1; but the number of primitives in the groups is 0, while there are a lot. Basically there are a lot of primitives, some have the word "rock" in the @name attribute, others don't I just need to isolate the ones with "rock" in the name. Should I be using a different function? Quote Link to comment Share on other sites More sharing options...
uakin Posted January 4 Share Posted January 4 try this code: if(match("*rock*",s@name)) @group_rock=1; Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted January 5 Share Posted January 5 It's also possible to use ~= for string matching. @group_rock = s@name ~= "*rock*"; in your case should work as well. 1 Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted January 10 Share Posted January 10 (edited) You can also just use a Group SOP, and set the Base Group to @name=*rock* Edited January 10 by eikonoklastes Quote Link to comment Share on other sites More sharing options...
