Run houdini using command line on Windows
JJ FX
Do you want to use houdini commandline version with something like hython.exe or do you simply want to start houdini with UI via commandline? For the first one you can use the houdini commandline tools which are installed with a regular houdini installation.
Edited by haggi
They are located in the install directory of houdini, in the /bin sub-directory, you can navigate to it using the cmd like this
cd "C:/Program Files/Side Effects Software/Houdini X.Y.Z/bin"
hython
// or
"C:/Program Files/Side Effects Software/Houdini X.Y.Z/bin/hython"
Or add the path to your binary directory to the user environment variable PATH and then it will "source" this directory and make the binaries available in any directory from the console. However I do not advise to do this, and instead make a little bat script that launches a console with Houdini binaries (such as hython) available, like this
@echo off
set PATH="C:/Program Files/Side Effects Software/Houdini X.Y.Z/bin";%PATH%
start /d C:/Users/username cmd
@echo on
And then double click on this script and you're set
Hi @JJ FX,
I have a script, which creates .bat and .py script:
http://lex.ikoon.cz/render-multiple-opengl-rops-simultaneously/
The .bat contents looks like this:
REM This batch file runs multiple .py scripts at once
start "Render: OGL" "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.416/bin/hython.exe" "Q:/volby/7 houdini/scripts/OGL.py"
The OGL.py looks like this:
# This .py script opens a file and renders single rop
hou.hipFile.load("Q:/volby/7 houdini/volby - v13.hiplc")
node = hou.node("/obj/rop_GL/OGL")
node.render(verbose=True,output_progress=True)
hython
// or
@echo off
@echo on
Thanks! :D
