Camera constraints - weight
On 4/8/2023 at 11:16 AM, Librarian said:
thank you for the reference. i had found the same example but didnt work. i ended up just using a Blend operator between the two cameras i wanted. CHOPs where not cooperating. the only downside with the Blend operator is that it only blends PSR values and not any other camera settings. For my purposes it was fine
