specific points along specific curves
christianl013
Hello,
I have a bit of a noob question here but I have not been able to find the answer otherwise.
How could I take a particle in a pop network work, plug in a network of curves into the
pop net and have particles only follow velocites of the curve with the corresponding
id attribute?
I have a name attribute for each curve and I have the particle with a matching
name attribute but I have not been able to get the particle to follow the curve
with the matching ID. I thought that I could do it with a pc lookup but it seems
to follow all of the curves in the lookup and not the curve with the matching
ID.
Is there a way to achieve this? any guidance on this would be much appreciated.
Thank you.
Best, Christian
I would use xyzdist to sample the curves:
https://www.sidefx.com/docs/houdini/vex/functions/xyzdist.html
You can use the overload that accepts a prim group where it be an ad-hoc group like so:
"@name=curve05", which would limit the look up to that curve where the name attribute is curve05. You would use this syntax to form the right curve for each point.
