How to get the number of points and show the number on the display
Posted (edited)
You can use the hScript npoints() function for that. Make sure to surround the function with the backticks so the font node will evaluate the function, and not display it.
Edited by Atom
Posted (edited)
Group the points by bounds, before you copy to points, then break off a network line and add a delete node that references the points in that group. Choose Delete Non- Selected, then have your font node reference the result of that delete instead. Which will be all the points in the box. You'd have to animate the box on the group node, however.
Edited by Atom
  • Like 2
