HerzogVonWiesel Posted June 3, 2023 Share Posted June 3, 2023 Hey there! I am asking for some help regarding water ripples. I've put this together in C4D but of course it's not in any way realistic, need Hou for that. I want to create water ripples emerging from the objects; and I've started using the shallow water solver, but I've not quite grasped the concept with how I would do these emerging waves (creating a volume velocity field was not really successful, (but I'm not super knowledgeable, who knows)). It's looking alright per se if I set the colliding objects as the seabed layer and input a water layer as well, however once I try to create the emerging ripples using the objects as a mask for the source layer, the whole sim breaks. If you have any advice, I'd love to hear it, maybe there's another better way. Thank you in advance! 2023-06-02 16-31-44.mp4 Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 6, 2023 Share Posted June 6, 2023 @HerzogVonWiesel if you mean this by periodic ..setup( Source Freq Once per Frame and Use Heightfield mask by object "above Surface"..(then you can use that mask for heigt or Sink endless possibility and dive inside Node and you can Change everything . or post your file for detailed investigation. Quote Link to comment Share on other sites More sharing options...
HerzogVonWiesel Posted June 6, 2023 Author Share Posted June 6, 2023 6 hours ago, Librarian said: @HerzogVonWiesel if you mean this by periodic ..setup( Source Freq Once per Frame and Use Heightfield mask by object "above Surface"..(then you can use that mask for heigt or Sink endless possibility and dive inside Node and you can Change everything . or post your file for detailed investigation. That is basically the setup I have going already. If you want you can take a look, but as you can see it breaks if I try to add more as a source (~Frame 55) water.hip 1 Quote Link to comment Share on other sites More sharing options...
HerzogVonWiesel Posted June 22, 2023 Author Share Posted June 22, 2023 Update: I got it fixed by limiting the maximum wave speed, seems that the simulation was getting out of hand by calculating bogus values without a limit! 2 Quote Link to comment Share on other sites More sharing options...
