houdini channel parameter interface bug?!
Hey Guys, my channels in my parameter view sometimes collapse from vector to one float.
idk why this happens oncei n a while but it turns me nuts. Only a restart helps since new nodes of the same typ will still have that issue too. Do you guys expierienced this issue too?image.png.531f16f42e165c650596626bdd85be15.png
Yes, I get this sometimes when I use Tab to jump between the fields as well, it's happened in multiple versions so not a new quirk.  I find if I reload the desktop that usually fixes it.  Sometimes selecting a different node and then reselecting it or clicking on the attribute name will reset it to the three fields again
For me it only happens, if the label field is highlighted (Pivot Translate, Pivot Rotate), if you click on the label again you can unhiglight it and it won't happen. There is also a X at the end of the edit field on the right side. If you click the "X" it also disappears.
@edit: "X" if you choose the first component "Y" ~ second and "Z" ~ the third in Houdini 19.5.xyz
Edited by Aizatulin
  • 1 year later...
